Bank 2 cat problem: O2 position 1 reading lean and cat twice as hot as bank 1
06RC
North Carolina
2006 TJ
Cleaned all injector and new orings and throttle body gasket and checked iac and map sensors all good new plugs new coil over bank 2 cat scoped it and looks bad and seems to be getting to much back pressure and plugs on 5 & 6 show lean but 4 looks good any ideas on what could be the problem? Maybe skid cat clogged
Sounds like you might be dealing with some clogged cats potentially.
When was the last time all the O2 sensors were replaced?
Reactions: tr21triton
Just replace both on bank 2 and it's not throwing any codes but on my scanner it shows bank 2 1 running lean the jeep has 160000 on it
I'm betting it's a clogged cat. I'd probably check your fuel pressure just to be sure it's within spec too. If it's running too lean that could exacerbate the lean condition leading to issues like this.
Still, given how many times I hear about issues like this and it ending up being clogged cats, that's what my money is on.
Yep checked fuel pressure and it is good 58 psi at idle holds steady and it i can take both post cat 02 out and leave plug in and it will idle almost as it should so I'm sure something is clogged up causing to much back pressure and maybe that's causing the lean condition on bank 2 cat because it gets up to about 600 degrees on it and front cat around 200
Yep, I think we’re both tracking. My bet is on clogged cars as well.
Clogged cat. The typical lifespan is somewhere between 80 and 120,000 miles for catalytic converters..
When I was little, I had a cat named Woem. That is meow spelled backwards.
My first thought is that the upstream O2 sensor was not tightened to the manifold enough to seal, leaking air in. However this should drive it to run richer.
Possible the injector seals on 5 and 6 are leaking air. Test by spraying some brake fluid or intake cleaner around the injector ports on the manifold and see if you've got a leak.
Otherwise, trouble in catville
Yeah done all that and replaced all the orings on injectors and switched around lol still same
Thanks
Ok finally found the culprit between cylinder 5 # 6 the exhaust manifold has a crack and sucking air.
So what is a good replacement for the manifold 2pc ? 1 pc ? I have already gutted the cats and ? Do hp tuner or what ?
Well found the problem there is a small Crack in the exhaust manifold between cylinder 5 & 6 and sucking in air.
I gutted bank 1 & 2 cats so I'm assuming the check engine light will stay on now.
Should I just keep stock pipes and get tuner to disable 02 sensor?
Yeah if you’re going to run it this way you will want new pipes and a tuner to disable the post-cat O2 sensors.
I'm running the Banks headers on my 97. I probably would have gone with cheapie Amazon or eBay ones just so I could cut off the donut seal and weld on a v-band.
If you live somewhere that doesn't inspect emissions consider simplifying exhaust to the earlier TJ style. Manifold to single downpipe to a cat next to the transfer case. You can move your existing O2s to make the PCM happy.
I thought about banks but have read so much about them cracking also.
So thought just doing the skp at 75.00 each
Reactions: macleanflood
