Gear oil smell inside vehicle after gear change
Steampunk
Cedaredge, CO
Hello everyone. A month or so ago I had the differential gears changed on our 2002 TJ Sport, Dana 30/Dana 35. It had the original 3.07 gears in it and has 33" tires. I couldn't stand it, so I had the gearing changed to 4.56. Perfect for all around driving and off road trailing. Here's my conundrum: After the gearing was changed, I noticed the smell of hypoid gear oil (if you're familiar). There are no leaks. I did notice that the small valve on top of the front axle vent was gone, so I replaced it. No difference. It smells more going uphill under load. Has anyone else had this issue and if so, what was the remedy? I'm going to take it to the guy who did the change for me this week and see what he thinks.
BTW, I love the gearing for my purpose. I did do the break in procedure per Revolution Gears. I'm at about 600 miles and it's time to change out the oil, per Revolution Gears.
Did you check the rear axle hose/vent?
The rear is going to be the hot one if you're not in 4WD.
No, I haven't. Tomorrow I will take a look. I was thinking it had to be. from the front, but that's a definite possibility. Thank you!
In warm weather I noticed that on my '01 4.0L w/ NV3550.
Took me a while to track down the odor, but I found that the inner shifter boot was ripped and the (4) shifter bolts were loose causing gear lube seepage.
I wiped down the seepage, tightened the (4) shifter bolts and replaced the inner boot.
No more odors... and that was more than three years ago.
I will check that Charles. I didn't get to try anything today as it was raining and then this evening had a three hour bout with Afib. Probably Wednesday is my first opportunity. That boot could be a problem as our Jeep has a B&M quick shifter on it. Strange though, it never had the odor before the gear change. Thank you!
Jumping in on this older post because I’ve seen this happen after fresh gear installs. You might want to check the axle breather hoses to make sure they’re not kinked or popped off; if they vent under the tub, you’ll smell it inside.
Also worth checking the diff covers for even a tiny seep that could be hitting the exhaust. Did the smell start right after the first drive, or only once things warmed up?
The stuff gets everywhere…..on skin, clothes, you name it….plus all over the axle at times-
I smelled like it for days after I did a regear
Reactions: John Cooper
