I test fit the five brackets recently received from SendCutSend today. First, I installed two nutserts for the bracket to mount the Switch-Pros control box and the ARB CKSA12 locker compressor on the driver-side fender. Fits like a glove:
And with the Switch-Pros control box and ARB locker compressor installed:
Next, I set up to drill holes for the nutserts to hold the bracket to mount an ARB breather for the rear differential inside the driver fender well in front of the taillight:
Just drilling those holes was a small project. A jobber-length drill bit in my M12 right-angle drill was too long, so I broke out the Vevor bit sharpener that Jeff turned me onto (thanks,
@NashvilleTJ!) and made a shorter bit to get the job done. Here's the breather installed:
Next, I test fit the bracket to mount a manifold and ARB breather for the transmission, transfer case, and front differential using the screws from the new electrical bulkhead connector I just mounted on the firewall:
Next up was the bracket to mount a water- and oil-separator for the York compressor and a manifold above the ABS tray on the driver side:
Here it is with the manifold assembly mounted:
And finally, I test fit the bracket for the Switch-Pros control box fuse behind the PCM:
And I designed another bracket for SendCutSend today. Since I've decided to switch to Fluxor's hinges, my old GMRS antenna bracket, which sat on top my MorRyde top hinge, no longer works. Keeping the same idea, I designed a bracket to sit on top the top Fluxor hinge. It's held on with the hinge's pivot screw, just like the old one:
It'll be cut from .125" 7075-T6 aluminum, and I'm going to try their powder-coating service. It'll be matte black.
Lastly, I started putting -8 AN fittings on the hose I cut to go from the York compressor to the water- and oil-separator shown above. I got one end on easy-peasy, but with my tank of patience below the E mark for the day, I gave up on the second after struggling for about 30 minutes on it. Tomorrow's another day.
Speaking of tomorrow, I still have to weld the bracket for the manifold assembly, and I'm going to weld some flange nuts on the front breather bracket to make it easier to install. Then, I'll bead blast all those brackets and paint them black. And I have to get the pesky AN fitting on the hose, yet, too.
I've also been mulling some changes to Fluxor's tire carrier to lighten it up as I alluded to in an earlier post. And I found that the pivot screw head for the top hinge hits my Savvy taillight, so I've got an idea to fix that issue, too. I'm going to flip the screws so they go in from the top, and then I'm going to install Keenserts in the bottom of the hinges so a nut isn't needed. Once I get those mods done, I can mount the hinges, and I'm going to use a long piece of drill rod to get the pivots coaxially aligned. I did that with the MorRyde, and the tailgate was smooooooth to open.
Lots to do! Stay tuned!
To see my weight-saving modifications to Fluxor's tire carrier, see
Post #766.
