Nashville TJ's Build - Continued
Edit: wait black bear pass??? In CO???
I hear Hyundai's and Subaru's can do it. ;)
So I thought it would be a fun project for an afternoon. I broke out my HP Tuners setup, and went to work:
When I updated the charging table, I had to modify my actual values just a tiny bit for the PCM to accept. Here are the actual charging voltages that the PCM would accept:
I thought I would be smart and actually test the results. So, prior to making the change, I fired up the HP Tuners data logger and ran a log. Voltage is tracked under "Control Module Voltage:"
Then I made the changes to the table, and ran another log. Feeling pretty good about my technical abilities at this point I exported both the before and after log data and dumped the detail into a spread sheet. I then averaged the before and after voltages, and here they are:
Stock Charging Table: 14.089 volts
New Charging Table: 14.097 volts
So yeah, my change did in fact increase the voltage: by 8 thousandths of a volt....
:oops:
Well, crap. It took me just a few seconds to realize what was going on. I run a Premier Power Welder on the rig, and guess what - it has its own 14-volt regulator.
Nothing like wasting an afternoon.....
Funny how you & I seem to forget this stuff half the time when we start to work on our rigs....
Now I wonder if there is a way to change the voltage of the VR of PPW? My guess NO but who knows.
I used to think eventually I wanted an onboard welder. Over time, however, I’ve watched folks (including you 2) who have them struggle with all sorts of weird issues. So my question is: with the new light weight suitcase welders, if you had to do it again, would you go that route?
Reactions: reddvltj and srimes
I think Victor @gasiorv has a carnage welder for comparison sake.
