Will I have interference issues between exhaust and rear trackbar with a 2.5in exhaust pipe, such as the one from Banks? This will be going on a LJ with a short arm suspension and Genright Safari fuel tank if these matters. This is not going in a stock application, and I will probably have the ability to shift the position of the tailpipe slightly, I just cannot make notches in the pipe to restrict the flow further since 2.5in will already be undersized compared to the donor vehicle the engine (GM LV1) is coming from. I just had lots of issues with my LS TJ and using 3in tailpipe around the trackbar area and had to make quite a few clearance notches, but I am hoping 2.5in exhaust will be good enough for the smaller engine.
https://bankspower.com/products/exh...006-jeep-wrangler-4-0l?variant=43028889862341
