Extra parts (transfer case edition)
inkedrose
washed up superhero
Arvada, Colorado
Draining my t-case and found a bunch of rubber when I drained it. Any idea what it is and solution to fix it? 2004 Rubi, 5 speed manual. The 241 with I believe the NV3550
So just leave it alone and call it a day? I filled and drained 2x to see if more came out
Yeah, if there's a lot it can block the filter, but other than that it's probably normal to have a bit. Someone who split the case halves added a bit too much RTV and it squirted inside, dried, and then broke off during use. Pretty normal.
Thats good news! Thanks guys
Reactions: Wildman and JMT
I just did the biggest bone head move. Was refilling with a hand pump and plastic end/hose shot into T-case... on way to get a bore scope now. WTF, one of those days. Might figure out how to pull a T-case after all. This started as a transmission mount swap
Welcome to my 30 days of hell...I pulled my case 17 times.
OHHHH MAN, that sucks! Amazon had a cheap bore scope should be here first thing in am. Hoping if i can see it, I can fish out the piece. Spent way to long trying to do it blind. It's a tomorrow problem now
