So have been considering options to get OD on a multi purpose TJ (70+mph freeway long distance, Dune riding and Rock Crawling) and seems like the only 2 reasonable options while keeping a 4.0L are the 42RLE and the AW4. Below is what I could gather about both options but looking for some more input from those with more experience with each or any other alternatives I am missing.
To preempt the OD and Automatic haters, I am aware and have owned the 32RH as well as an AX15, they are great transmissions but one is not an auto and the other does not have OD. This discussion is meant to be focused on options for those that have decided they are willing to trade some reliability and efficiency for an Auto with OD cause they do a lot of high speed driving and prefer Auto for their type of wheeling.
Gearing chart I created comparing many options to stock gearing at 70mph and when in 4 low (I didn't include all the 4:1 T-case options for simplicity in the list but obviously that would help further with the crawl ratios over the 2.72:1):
OD RPM target for 70mph is 2500 to minimize excessive downshifting and power loss in lower speed driving. Have accounted for 4% reduction in overall tire diameter while aired down for crawling. Not so sure about the OD RPM/Speed calc. I just dropped in 2400rpm for both transmissions and what the speed would be at. Need to do some more research on the OD triggers.
AW4:
Pros:
42RLE:
Pros:
AW4:
Pros:
- Cheap, Abundant and well documented install
- Generally considered good strength but don't have any definitive power limit numbers
- Hydraulic controls seem to be preferred over the electronic controls on the 42RLE
- Less efficient that the 42RLE, I believe I read reports of it robbing as much as 10% more power from @mrblaine
- Requires good external cooling as it is known for overheating in hotter climates
- To prevent it from upshifting from 1st to 2nd gear when crawling a separate circuit/switch needs to be installed or a stand alone TCU is needed
- No default OD off switch but it can be added
- ~3" longer than a 32RH but not clear if it is any longer than the 42RLE
42RLE:
Pros:
- Higher OD (0.69 vs 0.75), which I know some would consider a con if you aren't regearing with it in mind
- Option for the Rubi crawler to doubler to be added without extending overall trans length
- OD off switch option
- Less abundant and much more involved to install on any TJ made prior to 2003 (New PCM, wiring, switch to coilpack ignition, etc. on pre 2000)
- Requires good external cooling as it is known for overheating in hotter climates unclear whether it is any better than the AW4
- Generally considered less reliable than the AW4 from a strength perspective but have no info on actual power limitations
- Unaware of any stand alone TCUs for the 42RLE other than this new one without much info ( https://etranscontrol.com/shop/tcm-432-kit/ ) or HPTuners from my understanding can adjust the shift points
