I've got a lug when I take off into first gear or run in reverse, especially worse when I'm on an incline. My 2004 is a 5 speed manual transmission with the NV3550 and 88k miles. After researching I'm learning it could be the clutch or something related to the clutch. But I'm also learning that the OEM clutch that was used should last 200k miles plus even with abuse.. So what can I do to rule or rule out the clutch?
The gears also grind between first and second and third when everything is cold.. Fluids were changed about 5k miles ago and are not low.
Not sure if this matters, but I have a leak between the engine and transmission that has gotten progressively worse over the last couple of weeks. It will leave about a 2” circle on the ground over 8 hours. I thought it might’ve been the rear main seal, but maybe it’s something else?
I'm new to working on Jeeps, but can follow a good YouTube video.
