Yea ... I'm with Kenneth. Stock, everything is great, even on the surface of the sun I call home (Phoenix AZ). I've gone through 6 TJ/JL with the 4.0 and they ALL had reliable cooling systems and cold AC. Some of the crap hocked up as "upgrades" are anything BUT. The Problem is that we cannot get MOPAR parts as easily or at all ...
The Hayden severe duty will squeal the fan belt around 4000rpm, this is with all new belts, pullies, etc on a couple jeeps. MOPAR fan clutch seems just as aggressive but at the high end must slip a little more because they never squeal the belt.
Denso makes a fine replacement condenser that might just be the OEM part.
Water pump doesn't seem to matter much, but the Mopar always makes me feel better.
Radiator, They basically all have their issues, champion (3 and 4 core) , CSF heavy duty (brass), allow temps to creep a little but but Part store replacements are the worst. MOPAR just works, but those are NLA. I been running a "Cold Case" and it looks cools keeps cool, its a winner, but I cannot comment on reliability. I am about 2 years in with low mileage.
Hoses; Mopar is thicker and much higher quality.
Hose clamps... FOR THE LOVE OF GOD keep the spring clamps!!! you can get replacements at Bel Metric.
Fan; keep the stock metal, looks like a tractor fan but who cares, it works and has the ability to push enough air to squeal the fan belt.
Make sure you have a shroud.
I will add, sitting idle, you will experience the AC vent temps creep up a little but... you can raise the RPM a little bit or maybe consider an electric fan for when the AC is on ... that's probably the only cooling mod ill do... someday.
INSULATION and heat rejection for the interior is actually what most of us need. TJs/ LJs and prior are basically barns on wheels! We wouldn't expect our home A/C to keep a barn cool! Yes, we can get a certain temperature of air to come out of the vents but we won't RETAIN that temperature.
There's no "one size fits all" solution to that either.
You can't wrap your exhaust, in a wet climate.
Heat shields and heat barriers are nice but can obstruct views for diagnostic purposes and possibly come lose and rattle. Adhesive type insulation isn't always the best option for wet environments.
