Changing out the heater core (matrix): What do I need to consider?
Roger Dunning
Chichester, West Sussex, UK
My heater core went pop and has me off the road. I am getting orders in for the parts I need and wondered if people have insight into what I should be replacing as well as the heater core, and what parts I am going to need to buy. Alaso any other jobs I should be doing at the same time?
I'm in the UK but typically order from RockAuto.com
Any advice appreciated.
I'm doing this job om my 05 in fall. Core is currently bypassed as @KennethS suggested.
The evaporator core is inside the HVAC case. I'm changing mine out while I'm inside. I'm also replacing the AC accumulator/drier. Here's the parts list from Rock Auto.
FOUR SEASONS
54837
A/C Evaporator Core
FOUR SEASONS
98028
Heater Core
FOUR SEASONS
83106
A/C Receiver Drier / Accumulator
When I get inside, I'll check the condition of the mode/blend doors.
Also consider a seal kit. When I did my 03 Ram, all the foam seals were destroyed. This seal kit from E/Bay is sold by a forum member. See this thread:
Reactions: Roger Dunning
My 2005 TJ has the heater hoses bypassed, with prior core leakage likely the reason. Watching replacement vids discouraged DIY, noting my this TJ is a dedicated trail rig. With that, figured I'd just dress warmly when used off-pavement during winter months at 7k+ elev. Nonetheless, I'd much rather have the entire HVAC system functioning normally, plus the fresh and cooled air volume felt at vent registers is less than normal (having owned a 2000 TJ from new for 20 yrs). I did replace the control panel with an aftermarket SMP HS-373, which required rerouting the vacuum line bundle to HVAC connector, however net result wasn't much (if any) different. I also have a Dorman 973-025 resistor ready to install, however doing that same time as a new blower motor seems prudent, along with the task I've avoided being R&R of the entire HVAC box along with its internal core. So then, I'll be monitoring this topic for subsequent replies...
FOUR SEASONS
54837
A/C Evaporator Core
FOUR SEASONS
98028
Heater Core
FOUR SEASONS
83106
This is awesome. I really appreciate it.
FOUR SEASONS
54837
A/C Evaporator Core
FOUR SEASONS
98028
Heater Core
FOUR SEASONS
83106
I'm a right hand drive as in UK so I switched up the heater core. I think I will double check with them to ensure it is all good.
Reactions: Rancho LJ
I had a really interesting conversation with the chap who originally created the Rubicon! He's a brit and someone introduced me. When I said that I had a heater core gone he was surprised. He asked me if the radiator was ok, and I explained that it had just been replaced. He then said that the rad is the least path of resistance for a system that is over pressured, with the heater core (matriX) following after. Since both had gone he suggested that it could possibly be a head gasket that was the actual root cause. Hew was quick to say that it may not be but it was the first place he would check.
Super interesting guy and my god he knew his stuff.
I've managed to get a heater core and I'm having that replaced next week. I will also be getting them to test for the head gasket.
You could test / replace your radiator cap . that is the " pressure regulator " for the whole system .
