Hello all,
I have a 2006 jeep wrangler x with a 4.0l i6, 6 speed.
Recently replaced the clutch with an Exedy stage 1 clutch kit. This included replacement of pilot bearing, clutch disk, pressure plate, and throwout bearing.
Once I got it back together it drove fine for about 3 days then began to have issues with shifting. It would go into gear but had some creep while clutch was depressed. I thought that possibly the new pressure plate put some added stress on the stock master/slave cylinders, so I ordered a new set and installed. Have bled several times and was unable to get it into gear at all. I pulled everything apart again to inspect the new parts and replaced the fork pivot ball, the fork itself, and the retaining spring that holds it in place. Re-installed the assembly and tried it all again. I am still unable to get the transmission into gear.
The pedal feels as though I am not getting the full travel out of the pressure plate to disengage the clutch disk.
Could it be a faulty pressure plate? Do I need a heavy duty master/slave combo to operate the heavier stage 1 pressure plate?
Kind of at a loss here. Any insight would be greatly appreciated.
