I’m going to look into the stall test. And I will get back
Definitely something to look into for sure. I’m learning some new stuff every day but I am nowhere near as knowledgeable as @hear yet.
Let us know how it goes and we can help from there
Like @hear was saying, try a stall test. You can find your steps here in the manual.
Page 21 - 85 seems to address your issue shortly but I’d follow the testing procedures to be for sure and to determine which of the 5 issues may be the one you are experiencing
@Christian.mers @hear I completed the stall test, I used these procedures, the stall test did not go over 2000rpms
Hmmm, this is definitely where @hear shines for sure! To me it sounds like the torque converter is the issue and that’s what the this test is really signifying. I would replace that when rebuilding unless I knew 1000% that it was perfect
You’ve replaced and addressed every issue that I could think about regarding this matter. The only known factor is that your rebuilt trans was paired up with the same torque converter that was on the trans before it was rebuilt.
What did you say the reason for rebuilding was??
I completely understand the daily driver thing. This TJ is my daily and I’m having pretty much the same exact issue as you. I need a new torque converter and to rebuild the transmission, specifically the overrunning clutch all the way at the back. I’ve absolutely been putting it off because it’s my daily so I understand your pain.
You had a good thought thinking about the rear band not being adjusted and I’m sure that was probably something they overlooked. Definitely a shop error and I agree entirely on bringing it into them so they can fix their mistakes. I’m sure they wanted you to bring it in so they could figure out if the bands were adjusted properly and test drive to make sure everything was in order
Sorry I couldn’t help anymore, definetly out of my knowledge range at this point in time. You’re absolutely have to let us know what the shop says and if your issue is resolved
You’re absolutely welcome man, the forum is here to help you so feel free to reach out any time and someone will help you for sure.
On side note, where did you find and purchase your Transmission Manual? I’ve been looking here and there but haven’t really sat down to find it yet
Thank you For everyone’s feedback, I agree I will take the transmission back to the shop. It’s part of the shops procedure. The shop I went to is called certified transmission and has the best ratings in the north valley of Arizona. They’re super friendly and and he told me once I finish installing the transmission that he wants me to bring the jeep back anyways so he can go over everything. I just wanted to see if there was something I could fix or learn about this situation, before I’m jeepless for a few days
Absolutely best thing to do. You paid for this, let them dial it in.
Hmmm, shifting into 4-lo could be masking the issues because it’s giving you a gear reduction from 1:1 to 2.5:1 that you only get in 4-lo. That’s why you probably don’t experience the changes in 2WD or 4-hi. This makes the jeep move forwards and shift through the gears much quicker because it’s practically masking the issues. The torque is being multiplied 2.5 times what it normally is. Which is where the 2.5:1 comes from, every input of 2.5 results in 1 output meaning you’re getting 2.5 times the torque and output from your engine. All that rambling aside, let’s get to what I’m thinking…
The Linkage issue: if your linkage isn’t properly adjusted you may not be all the way into the proper position so you could be pressing the accelerator and it not moving until it catches where it needs to be to start moving. What I’d do is go through the gears on gravel or something that isn’t hard and listen very closely for for delays, unusual clunks or thuds. I’d look at the linkage for loose bolts or bent rods or bad bushings.
The driveline issue: Do you have any vibrations? Jack up your rear (put it in neutral) and see if the rear shaft spins smoothly and listen to any weird noises. Your front diff could be pulling the weight that your rear isn’t? Maybe you have bad u-joints that are binding?
Thank you for your input. I’m going to try both of those right now. First I’m going to jack up the rear and look at my rear drive line. I have noticed a little bit of clanking when I’m trying to drive. I thought that could’ve been my control arms or old Springs or something but hearing you say that makes me wanna jack up the rear and look for myself I’ll get back to you here in a bit
That has to be the problem and hence why four-wheel low feels normal I’m going to remove my transfer case and see what the deal is.
