Well I'm pretty sure I have a unit bearing going bad. Over the weekend drive it started a really hard pull to the right, with a nice burning smell and inconsistent front steering wobble mimicking DW or bad balanced tires. Same symptoms as when the TJ hubs went out. No noise yet though.
So looking at options, Just curious what the community thinks in terms of best replacement options. Of course OMIX and Crown are options. MOPAR I can still access. Then gatertamer posted a nice link to MOPAR bolts, but timken bearings.
Then theres the consideration of while I'm there replacing the stock ball joints and brakes. The ball joints I think are going out anyway. I'm considering spicer. The brakes, at the least, could be refreshed with new fluid.
While I'm at it. I was looking at the Vanco 15/16 big brake kit with the upgraded knuckles.
But back to the topic at hand - any preferences for MOPAR vs. others for the hubs? Of course if going with the BMB kit it would be much easier to use the pre-machined unit bearings.
Yeah just found these....even Mopar
Jeep Wrangler Cherokee Hub Bearing To Knuckle Mount Bolts Set of 6 OEM https://www.amazon.com/dp/B01CIOC66Q/?tag=wranglerorg-20
