I have a 5.3L LS (stock), 4l60e (stock), and current rear is 4.56 that the previous owner did. After reviewing his receipts from a million years ago, I'm not sure if they actually did the front regear, I've only used 4H once in the sand for a few circles. Non-rubicon so Dana 30/Dana 35 set up. This is a fun weekend pavement princess that my kids enjoy, I don't off-road currently.
As my other post eluded to, I'm chasing acceleration / pep with the LS swap and considering a higher stall torque converter (need to fix a rear main seal leak anyway). My Dana 30 needs brake upgrades and new ujoints, probably bearings while I'm in there. So, I'm considering going to a currie 44 front for now and eventually probably a currie 60 in the rear to get disc brakes and the HP as I hope one day my kids drive this rig and want it to be beefed up, reliable, and easier to maintain (and/or more sellable). Currie caster / pinion angles would help with on road manners as an added bonus. So, the dilemma is, 4.56 vs 4.88 vs 5.13 gears, Currie recommends 4.56 or 4.88 for me.
Again, I don't necessarily care about highway RPMs or gas mileage, but want pep, seems like 4.88s are the way to go, or would 5.13s be ideal? However, I'm not sure of the "value" of going from 4.56 to 4.88 in terms of real world off the line performance. Most posters on here are thinking about highway rpms (I have the overdrive .70 in 4th) or off-road performance, but I'm wondering if the acceleration is worth the investment. I couldn't justify re-gearing 4.56 to 4.88 solely for the performance but as I mentioned, there are many other benefits of the new axles. Much cheaper route is obviously just do the u-joints, bearings, and do a black magic upgrade and call it a day but what's the fun in that?
If I go the expensive route, I'm ok with the investment and the learning process as I do all the work myself (and I can make a few YT videos to help others). I do like the plug and play currie vs used axles that I'd have to work on / re-gear / re-work brackets / etc.
What would you do if you were me?
