Several years ago, I purchased a used long block along with a Magnum Powers Supercharger. #4 and #5 were burned up so the intent was to bore & stroke the motor, building it with low compression for boosted application. The motor was sent to a local machine shop where the engine was machined, built, & blueprinted into a 4.7L using the following parts:
05 Block
SCAT 9-4-2L-3895 forged 4.2L crankshaft 3.895" stroke
SCAT 2-ICR40L-6125P forged rods 6.125" long
ICON IC668-040 forged pistons 3.195" bore
Edlebrock performer aluminum head
Harland Sharp 1.7 rockers
I lost the cam specs but I recall the compression ratio being computed at 8.9:1. After much reading, I think my plans will change from a boosted to naturally aspirated motor. Am I better off revisiting the engine build to raise the CR? Who's the go-to for 4.2L-4.9L strokers so I can wrap my head around my potential mistakes? Desired goal is around 330 lb.ft. and 280 hp.
05 Block
