I've noticed my Jeep has had a few leaks. It has almost 250000 miles, the previous owner used high-mileage Valvoline oil. I have done two oil changes and used non-synthetic Rotella. I just bought some "all-mileage" Valvoline to see if that will help with the leaks some, I couldn't find a "high-mileage" oil that wasn't synthetic. So hopefully the all-mileage will work good.
I've had the Jeep start to overheat a few times in traffic, and the radiator would be empty. My coolant reservoir has a piece of plastic 1" diameter pipe floating around the inside of the reservoir. I just ordered a new reservoir and thought maybe it had something to do with it. I also changed the spark plugs about a month ago and the furthest back plug was oily.
Besides the overheating problem, it runs fine and strong. Heres a few spots I've noticed fluid 1. The thermostat area 2. back right & left of engine 3. theres also oil on the front of the oil pan, not sure where it started from though.
