Warn M8000 reconditioned tips
I use a Tectran 19-1021q but any quality monetary on/off/on with 6 blades will work.
Blackjack, older thread of mine, but I just pulled the wire line out to responds, just make sure all is good etc.
Half way in it stopped. Nothing. Seemed hot. Waited 45 minutes and came back, and it spooled fine.
I got these solenoids off Amazon, have yall seen cheaper ones overheat?
Want to isolate that before digging into other possibles
I’ll have to look at this. I’m not a winch expert, so this replaces the controller and controller box? So I wouldn’t use the controller etc?
that's a warn contactor used on alot of the newer M8000's in lieu of the solenoid-style you have. You could mount this contactor in the engine bay, run properly sized wires from this to the winch. Then you can run light gauge wiring to in-cab winch control and wire per 12V guy's instructions.
https://wranglertjforum.com/threads/5-pin-winch-controller-in-cab-wiring.13581/
Reactions: tnjeepguy
