Had to put the new flares on. Black Friday pop up tent worth every penny.
Zorb - what do you illuminate with the Rock Lights down there in Florida?
What no food?????
Haha Sorry, not this time ..I had half a candy bar on the dash if that counts ? haha
Scary climb. I heard he almost had to use the winch.![]()
Do those things just pop out & pop back in? I need to replace mine, but I’m a little afraid of screwing things up trying to remove the old ones. Do they just pop out & the new ones pop back in? ‘Any tools required?
Thanks in advance.
these ones are a little cranky
Looks like there's some wet rot there, too.That's called dry rot here. This is cranky.![]()
Over the weekend...
Finally got around to installing the shocks and 2" lift...
So, I spent many many many hours only to replace the front shocks. I was humbled... but I had "fun" and it's drivable again. Likely to seek professional help if I ever want to try a lift again.
- Took the boxes off the shelf where they have been sitting in the garage all winter.
- Jacked up the front
- Removed the front wheels
- Detached the sway bar links.
- Dropped the front wheels down.
- Removed the coils and went to the autoparts store to borrow a coil spring compressor
- Spent hours trying to figure out how to unbolt the top of the shocks with lots of youtube video advice...
- Tried the 1/4 inch wrench and it wouldn't grab
- Tried "cut away the rubber spacer to get hold" (no luck)
- Remove airbox to access from above (no luck)
- Tried "just pull the bottom and break it off" (surprise, that worked)!
- Spend more hours trying to figure out how to push the rubber bumper and metal connector through the whole at the bottom of the shock.
- Tried greasing it up and pushing it through (no luck)
- Tried a vice but my vice wasn't big enough
- Finally had the idea to use the weight of my camper and camper jack as a makeshift vice (surprise, that worked)!
- Removed bump stops and tried putting the cools back with a rubber spacer and bigger bump stocks.
- (1) Realized that I would never be able to do that.
- (2) Realized that the rubber spacer was probably not a great way to Lift it anyway
- (3) Realized the coil spring compressor I borrowed from the auto-parts store was not worth the risk given the above.
- Reinserted the old bump stops.
- Reinstalled the old springs.
- Reinstalled the tires.
- Returned the coil spring compressor.
Over the weekend...
In progress photo:
New shocks installed and it all put back together photo:
