My daughter is having issues with my old jeep that is know hers. Drives around town with no issues. Drives (65-70mph) on the hwy and stalls, sometimes. These are short hwy distances 10-15 min. Normally she will call me. I drive to were she's at, crank it up and drive it home and it seem fine. This only happens to her on the hwy. There are no codes, no check engine light, no signs.
Some issues I know of:
I had this issue 4 yrs ago with the stalling. Only difference is I couldn't restart the jeep for hrs after it would stall. Mechanic replaced Crankshaft position sensor (unknown brand probably NAPA), Fuel pump (Delphi). At that time 4yrs ago I was getting along start were I had to prime the pump by turning the key twice. Not sure which fixed the problem since they were both done at same time, but the stalling issue was solved. For some reason I did still need to prime the pump to start, but hey it didn't stall so I was good.
Today I was looking at the crankshaft position sensor and noticed the corrugated wire surround is melted from resting on the block. It doesn't appear the wires have melted but I need to inspect better.
Thoughts on were to start to figure this out?
