OEM bolt specs for center console
550+
Revelstoke
Is someone able to provide me the OEM bolt specs for:
1.Front center console base (under front cupholders)
2.Rear center console base (under rear cupholders)
My goal is to replace the bolts with ones that are ½″ longer to accommodate the thickness of the new sound-deadening under the carpet. While Google suggests they’re M4.2×1.69×19 mm, the parts the local nut-and-bolt store gave me didn’t match. I want to make sure I order the exact correct size and thread so I don’t risk damaging the console’s mounting holes during installation.
Offhand I don't know, but there are service manuals and parts lists available for download here in the resource section of the site, all TJ years covered. You should be able to find solid information in the parts list documents.
Walk into any ACE Hardware (or local hardware store) with the bolts and test fit them into the bolt thread sizers they have in the hardware aisles
You can get just about any bolt size there in a pinch. I order all my Grade 8 yellow zinc stuff from McMasterr Carr since Im local to one
Support your local hardware stores before Amazon chinesium is all ya have left
Reactions: TheBoogieman
