Don't give them any ideas
Didn't know it was that bad... We're CA north & you're CA east...
We've adopted the CA regs unfortunately. I think that occurred in 2020 maybe? No safety inspections thankfully
WA stopped doing emission testing about 10 years ago. Where I live it wasn't required but they did in the more populated areas.
I don't need to smog anything in my county except to first register when buying or bringing from out of state. Sniffer for 1999 and older but just a visual inspection and obd2 readiness check for newer cars
CO is similar. Essentially the front range from Fort Collins down to Colorado Springs is subject to emissions, the rest of the state has no requirements.
I was about to ask about if you got the sniffer from your original posted data because here in MD we have do to emissions every 2 years but for any OBDII - it's just a plug-in check and go.
Ran a quick check of MD standards and it looks like we don't require sniffer for anything 95+ with OBDII...
Glad you passed! I recall throwing parts at my 91 Camaro to get it passed on the sniffer (Back then in PA and you failed, you just had to spend $150 in parts (not labor) to 'try' to pass and you 'earned a pass', but it was every year testing) — I'm sure it felt good to get the manifold replaced, knowing that would help pass the test.
At least the last 2-3 tests, mine just gets plugged into the odbii reader. I don't think they have run it on the rollers or used the sniffer above an idle since I put on 35s.
I was surprised to find it was tough to find a shop that would align a vehicle on 35s around me.
I get your thinking of surprise they'd run yours on 35s on the rollers. I guess there's enough (older) lifted trucks in CO to justify equipment that will fit/meet the requirement to survive requiring regularly spinning that mass.
We can bypass sniffer if we go by two "roadside" checks a year. These just sit on the onramp to the main highways and it seems easy to game. I just check where they are every few months and make a pass in each car.
When my jeep sat a couple years I missed it and they said they can't do 35" tires or bigger at most of the emissions locations and tried to tell me I had to go somewhere else. I pushed back and they just passed me anyway.
I'm hoping to register a new 1981 F150 outside the Denver Metro to avoid having to care at all for a vehicle that sees like 500 miles a year.
I don't know how it is supposed to work and I don't question it. There are more than enough giant brodozer trucks that need emissions out here. They can't all be installing smaller tires for a day.
We can bypass sniffer if we go by two "roadside" checks a year. These just sit on the on ramp to the main highways and it seems easy to game. I just check where they are every few months and make a pass in each car.
I was reading into that while waiting at the facility. You have to pass 2 roadside checks a year, but they have to be 14 months within your emissions expiration date.
I have long been suspicious of that because I drive past those frequently and I never see any method of capturing a license plate.
I had broken a spot weld when the tailgate took a hit at Moab. Josh bedazzled it yesterday.
