4.0 manual knocking only when how
thameren
bc canada
My 98 4.0 with 245k km has started knocking only when fully heated up at idle doesn’t happen every time and and once the revs go above idle it stops and it will randomly stop it definitely seems to be in the oil pan I’m running 10w30 Lucas high zinc wince it’s a very old design motor and it always makes good oil pressure 35psi idle when hot and 50psi driving at 2k rpm
Well everything we can do is a wild ass guess born from some experience.
For a definitive answer you need to tear the motor down. Oil pan, pull the head...pull the pistons off the crank.
You might be able to guess more scientifically with more data... compression and leak down tests...oil analysis from Blackstone.
DeXJs has some excellent videos of quick and dirty 4.0 refreshes.
Pulled the oil pan today and everything looks good no cracked pistons and con rod bearings look good pulled the oil filter part with a cutter and there was lots of material and compression was good on first 3 last 3 where 110 80 and 70… guess it’s time for a rebuild
Reactions: macleanflood
