I have a slow leak of Power Steering fluid, which seems to be coming from the pump itself. The fluid is darker than should be, which might be from deterioration of a seal?
Question: In the same way that high-mileage oil, or additives, can restore seals to stop a slow leak, can I use something like this product? Looks like Jerry Bransford once did the same.
Note: My manual says to use "only petroleum fluids formulated for minimum effect on rubber hoses", and not to use ATF.
