Time for new drums on the back. Anyone running a particular make? More importantly because they’re just drums - any make I should avoid? Cheers.
I installed power stop drums last year, no complaints thus far.
How did you check them for being round?
We've checked several by just laying them on top of each other. They don't line up at all. If you get a lathe, don't make the mistake that causes the problem we have now that can't be readily fixed. They are grabbing them with a 3 jaw chuck. The clamp pressure is too high so it distorts the drum. They machine it round and then when they release the jaws, what they get is a large rounded corner triangle that isn't round. Don't do that.Same way we do straps on vehicles...say the magic words "that ain't going nowhere."
I have a mismatched set...they almost have 3/4 lbs of weight difference between the two drums... they're in spec but I know better than to check if they're round.
Got enough stuff keeping me awake at night...
Need to get a lathe and just make my own...
Anything from some noise, to practically not able to be noticed, to a pulsation in the pedal. Mainly the easiest way is to install them with some nuts to clamp them tight and idle it in gear. See if they wobble.I'll be honest, I didn't know I needed to. This was the first set of drums I've ever installed. How would an out of round drum act while driving or braking, bad vibration?
Belly dancer friend of yours?I bought (2) AC Delcos from Warrior Woman.
Belly dancer friend of yours?![]()
