Opinions on 2000 TJ condition (pictures included)
The search continues!
If you buy one out of state, will it pass Cali emissions to register it? Also, will it still cause cancer without the Cali labeling? :unsure:
Looks pretty decent. A couple of notes:
  • Set up with four-flat wiring for towing and flat towing
  • Missing steering damper
  • Ripped away bar link bushings
  • Looks mostly stock, unchanged from the factory
  • Equipped with the less desirable rear Dana 35 axle (doesn’t hold up to big tires as well)
  • Rust is not bad overall, but I recommend a very close look at that rear driver side area of the frame
