How do I delete the A/C in my TJ?
TJonfire
Hamilton
I plan to delete the AC in my 01 TJ project. I have it all disconnected (the body is off rigjt now). Wjat do I have to do in terms of the belt and the AC pump. Can i simply get a smaller belt and bypass that pulley?
I suppose if the body is off and you're 100% sure you don't want it, in terms of the belt, you can simply run the non-AC belt. Then just unbolt the compressor and pull it off being VERY sure to properly evacuate the refrigerant in the system 🤫🤐.
The non-AC belt is a direct replacement and can be used to bypass the AC compressor, my 2003 had a belt diagram near the grill. Yours may or may not depending on the year, but you can find it in the FSM's available on the forum. The compressor should ideally unbolt, though I've never done a 4.0 TJ compressor.
Reactions: TJonfire
If you are going without ac, I would leave the pump in and turn it into a high volume air compressor. That way you always have air and only need to carry a hose. Fill your tire in one minute.
Reactions: TJonfire
Personally, I can’t imagine having a vehicle without AC. But I have always lived in areas with high temperatures and/or high humidity.
Reactions: BlueC
Your options:
1) Remove the compressor and run a shorter belt
2) Use your A/C compressor as a air pump for filling your tires & having onboard air.
https://wranglertjforum.com/threads...on-of-stock-jeep-wrangler-tj-a-c-system.3672/
https://www.jeepforum.com/threads/a-c-to-oba-conversion-write-up-pics.471962/
https://www.pirate4x4.com/threads/sanden-compressor-on-board-air.141734/
3) Run a A/C delete pulley:
Reactions: jeepguy03 and BlueC
Your options:
Why would you ever do 3 if you can just run a non AC belt though? Surprised that would even exist
Reactions: TJonfire
I guess some just want to use their current belt? Or the routing of the belt doesn't work well without the A/C pulley being there?
I just know there are kit available.
But it can't be cheaper than a new belt can it? And there is a routing for no aC compressor, I don't have one. Idk just weird it exists lol
That kit was $75 from AutoZone.
I had one on my Magnum engine because I was going to try to install A/C again at some point.... The Hemi didn't have A/C when I bought it but I added a compressor and the other required pulleys.
I honestly don't know why they make them. One reason I could see is if your car came with A/C and your compressor failed it's a temp fix until you can get the new parts to have A/C again. Because on some engines going from A/C to non-A/C is more than just deleting the A/C compressor.
My little 4 angry squirrels had A/C on it but when I did the V-8 swap the shop didn't add it back on like I'd asked. And by that point I just wanted my Jeep back.
Reactions: lBasket
I would leave the AC. It adds value to the Jeep. As long as it is off, it doesn't do anything. Plus, it is probably just as much a hassle to remove it as it is to fix it. It is better to restore a vehicle than hack it to bits. The next owner will appreciate that you took care of it.
