What is the best winch for my Jeep Wrangler TJ?
Is there any worth getting a stronger winch to make recovering others easier? I'm asking cuz my younger brother has a full sized truck, and drives like a younger brother.
If you do a lot of recoveries or your recoveries tend to be slog fests then having more winch is not a bad thing. Problem with putting on a larger winch because you want to recover larger vehicles is that it will not work. Your TJ weighs less than they do so unless you plan on anchoring yourself down and adding that stress to your chassis you would be better off setting your brother up so he can self recover.
Anchoring my Jeep wouldn't really be an issue. But ya, my major concern is how well the TJ frame can handle it long term.
Would I need a winch plate for this?
You wont have an issue if you get a 12K winch. Obviously a good winch plate and rear bumper are essential. Take a look at a 6 ton press, the steel that supports it, then take a look at a Jeep frame. 12,000 lbs isn't enough force to permanently bend the frame and the winch will catch on fire before it gets much past that number. 12k is also fine for full size recovery.
Sorry to post in an old thread but I'm looking at a used Warn m8000 and didn't know if this is worth checking out.
From the description: "I have a warn m8000-s winch synthetic rope like new been on vehicle never used comes with a corded handle and a wireless programmable controller"
Seems legit but has been posted for a few weeks which always scares me.
View attachment 603045View attachment 603046
It looks OK.... If the price is right then I'd go look at it.
Dan, I have no knowledge about replacing steel cable with rope on an existing winch, but I do know that Warn uses the same 3/8 synthetic on both the 10,000 and 12,000 winches. It is definitely up to the task and kind of the standard size for the 8,000 to 12,000 class winches.
I finally made the switch to rope and have never looked back. I wish I had done it sooner. You need to learn to keep it out of the sunlight as much as possible and learn how to splice it, but there is really nothing to it. You can learn to properly splice it in 10 minutes.
Hope this helps.
Reactions: tnjeepguy
Hope this helps.
Who is Dan? 🤣
Reactions: Zorba
I realize that this is an old thread, but it is, in essence, an ongoing discussion of the M8000 and began with Chris’ strong confidence in the M8000.
I’ve had a Warn winch on on my various different trucks I’ve had since 1977. The formula that has always worked was having a winch with a bare minimum of twice the GVWR of the truck and this math has served me well.
When I started looking for a Jeep a few months ago, I had it my head that I wanted the overkill of a Zeon 12000 pound winch. When I found the Jeep I purchased, it had a virtually new M8000 steel cable winch converted to synthetic. I was ready to sell it in favor of a Zeon until I read Chris’ glowing endorsement. I decided to leave it in place and give it a chance. After all it does meet my twice GVWR formula and it is a Warn product.
Today, I got mired to the rear axle in one of those suction cup kind of bogs. Lockers on both ends and 35 Mickey Bajas didn’t get it out of the thick glue. A tree had been kindly placed by God in the exact location I needed. We used a soft shackle snatch ring for a double line pull, which sort of indicated my lack of confidence.
The front axle wasn’t as deep as the rear and when I started winching I noticed that the left front wheel wasn’t turning, but the vehicle was moving fine. I stopped immediately and realized I had left it in gear by mistake. It was dragging the Jeep on the non turning wheels!😳. Hope that mistake didn’t cause damage to be discovered later.
Anyway, I just want to admit my lack of confidence was unwarranted. This winch is, as Chris claimed, the correct winch for a Jeep and Peppergat did a very solid installation, both mechanically and electrically.
You don't need a winch, until you do. And that is the precise moment you'll wish you'd spent the money on a good one.
This is in line with something I’ve said since I was in the Army fifty years ago and that is: “You never need a pistol until you need it BADLY.” Same goes for a winch. Had I not had a capable winch yesterday, I might still be trying to walk out of those woods.
Reactions: OffroadTreks
Does the dog come with the winch?
