Installed JKS 2" Question
Just wanted to update my post. Rear shock mounts had been replaced and set the shocks up much shorter. I am removing and welding on stock location mounts.
Spreading out the distance between mounts will be good start. When we outboard the shocks, that is one of the things we are doing in order to fit a shock correctly.
Reactions: interceptor1972
So I put the 2.5" jks lift kit on my jeep tj 2004 2.4l and now whenever I'm in 2nd or 3rd jeep vibrates. It's mostly in the steering wheel also there's a weird popping sound whenever I turn the wheel to the left. None of these issues were here until after I lifted. I run 32s and my previous suspension was the stock springs im at 130k miles. Does anyone know why my jeep decides to become a giant vibrator?
I had a hint of a vibration from the drive line with this lift. Go throw a couple hundred pounds in back to settle the suspension lower. Test drive to see if that helps. By the time I had a full-size spare 33” and a hitch bumper the vibes were gone. Doesnt address your steering pops- check bolts are torqued maybe track bar play
I just installed a steering stabilizer, since the one I had was stock. Hoping that it would help with the wobble at 50mph. It really hasn't. If anything my death wobble has gotten worse since I lifted. Has any one else had their issues with the lift kit making their jeep more susceptible to the death wobble?
Man my streering pump jumped out from the death wobble
Loose front end parts,tires out of balance or out of round,rims not running true. Any kind of front end shimmy can be traced to those. Start your own thread after putting in the work to find what I mentioned
