Name that tune: Jeep squeaking when driving
JessicaJeeper08
Huntsville, Alabama
Please help me determine where this squeaking is coming from or things I could check? I think it’s coming from inside the cab but I can’t tell for sure. This happened before I had all new suspension and steering parts installed in January but has continued after the work was done.
Disclaimer: I was driving on my private property just fyi
Sounds like the Blower Motor or Fan Cage for the A/C up in the passenger footwell. It sounded like you had the blower motor ON.
Does the sound go away with the FAN in the OFF position?
If its not inside then crawl under your jeep and tighten each of the 6 body mount bolts on either side of the tub by 1/4 turn and see if it goes away.
Reactions: JessicaJeeper08
I will verify tomorrow because I can’t remember crap but I think it still happens when the AC is turned off. I also noticed it seems to happen more when I get into 5th gear. I will have to do some more investigating.
If it only does it in 5th gear what happens if you're driving down the road and you press the clutch pedal in? Does the squeak go away? It might be your throwout bearing.
