I pulled my rear axel apart to do gears. It didn’t have the large slinger between pinion and pinion bearing like in the front, there is a shim but much smaller diameter. Two of the pinion preload shims were tore up and the outer pinion bearing was loose on pinion. Just making sure not missing anything here?
