I hook my winch line to it since I run a standard hook that doesn't fit behind my license plate bracket very well.
A soft shackle is perfect for that. No need for a steel shackle.
I did that with my ATV and the sun degraded the soft shackle really quickly so I stuck with the metal shackle on the front of the Jeep.
Why are you storing soft shackles outside the vehicle? Put them in the recovery bag.
Either way, your soft shackles should survive just as well as our synthetic winch ropes do out in the sun.
I think something got lost in translation along the way. He has a hook at the end of his winch line. While in transit, he has the hook attached to a metal shackle that lives on one of his d-rings. If he used a soft shackle rather than steel for this, the sun would eat the soft shackle.
FWIW I am also not a fan of steel shackles being full time on the bumper just because of the extra rattling. But for his use case, there would be no rattle since the hook would keep the shackle under tension.
Maybe so. And if so, then we have very different philosophies on building a winch and recovery system.
The hook is free. Most alternatives are more better and more expensive.
When I had a hook I just pulled it against the fairlead
Interesting. Any issues with it banging around on the highway? I've got a safety thimble with the matching fairlead so no personal experience with a hook setup. The guys I wheel with have hooks and they store them attached to shackles on their d-rings.
Why not rope to D ring?
Less connections, less risk.
I don’t want to remove them.![]()
Safest way.![]()
So...it's not the Safest way, it's the Easiest way.![]()
Without pictures, translation problems are prevalent in the recovery world because there are different terms for many of the components, many of which describe other components used in other worlds. For instance, in the lifting world, this is called an "anchor shackle" (more specifically, a "screw pin anchor shackle":I think something got lost in translation along the way…a metal shackle that lives on one of his d-rings.
In the cargo transport world, this is called a "d-ring":
But, in the recovery world, the two terms combine to call this a "d-ring shackle" (most of the time that I've seen):
And now you've used d-ring in a new way (to me) - to describe this:
I'm so confused!![]()
Maybe we need a "Jeeper's Glossary" in the resources section...
What do you call the removable recovery and lifting points at the 4 corners of a Humvee?Without pictures, translation problems are prevalent in the recovery world because there are different terms for many of the components, many of which describe other components used in other worlds. For instance, in the lifting world, this is called an "anchor shackle" (more specifically, a "screw pin anchor shackle":
I'm so confused!
I don't know - I've never seen them. However, my neighbor is a retired Army lifer who was a fleet manager. I bet he could tell me what Uncle Sam called them...What do you call the removable recovery and lifting points at the 4 corners of a Humvee?
As have I. In fact, Crosby bought Gunnebo a few years back, so now, you can see both terms used on the same web site (Crosby). Crosby calls them anchor shackles and Gunnebo calls them bow shackles. Come to think of it, "anchor shackles" could be a maritime term. Like I said - it's confusing...While I do recognize the accuracy of anchor shackle, I see them called bow shackles by a lot of the higher quality companies.
