2004 Wrangler 4.0 42RLE automatic
Hi all,
I've made a post about a year ago now of a noise with my Jeep. I was never able to figure it out and life has gotten in the way so it has stayed in storage on jackstands. Today I took it out for a drive to jog my memory of the issues it was having. Whenever I am stopped and put the jeep in reverse or drive it makes a whirring? I'm not sure how exactly to describe it. The noise fully goes away when it is in park or neutral and gets worse as the jeep gets warm. It will also go away at about 30 mph until I slowdown to a stop again. It seems to shift fine to me there doesn't seem to be hesitation between gears but I'm not sure how transmissions work or even how it feels when the converter locks up. It did have a used transmission swapped in about 5 months before the sound showed up. I'm about ready to bring it to a transmission shop as I just cant figure it out but thought it would be worth seeing if anyone has experienced this. I have attached videos to show the sound. It gets louder as I rev it and when you hear it go away in the video is when I shift it to neutral. Thank you very much for any insight
I have checked,
Fluid (while running in park full to hot with atf+4)
flex plate bolts all seem tight no sign of wear like rubbing on something
removed front driveshaft to see if that changed anything (it did not)
Video
Video
The noise also seemingly goes away when it is in the air which also doesn't make it easy to diagnose.
Hi all,
I have checked,
Video
Video
