Hello all. I've got a whole laundry list of things to fix. I plan on starting the whole dance around the end of this month. Sorry for the long post...
Currently we're lifted 4.5" and on 33" tires. We're rocking the 6-speed, and ...3.07 gears... So regearing is going to happen. I've decided to go with 4.56 after hours of back and forth on forums.
I need new carriers for the front and rear: Dana 30 front and Dana 35 rear. I am not sure if I want to get open differentials right now and save some coin, or if I want to just do it right the first time and put (enter suggestions here) in the back and a PowerTrax No-Slip in the front.
What's y'all's opinions on how best to go about this? I'm assuming that if I regear the front and rear end now with open diffs, I won't have to do the whole backlash and gear mesh tedium when I replace the boring open carriers with less-boring options.
This jeep will be a daily driver when I've got it all ironed out. So I reckon an elocker in the back would be most ideal? But, I'm considering a TruTrac because I'd prefer the vehicle more versatile in all conditions. I will see all manners of rain, snow, ice, mud, trails, etc... Basically everything except knarly rock crawling... for now... It's more important to me that I can drive this Jeep from Arkansas to Michigan than it is for it to rock crawl.
For those that are curious, my to do list is:
Regear front and rear to 4.56
Cut and Weld rust repair on belly behind drive seat (common spot I'm learning)
remove and rust repair hood
Tcase control cable upgrade
Door seals
Tail Light replacement and re-wire
Compressor relocate/air tank delete
fresh sauce all around
hard top seals
I will be doing all of it myself
Door seals
hard top seals
