Creating a Jeep TJ truck
JamesBuhr
colorado springs
I have finally acquired 3 jeep TJ's, and can now start building a truck out of the parts.
2000 green 4.0 manual 5-speed green jeep Wrangler sport, - good jeep minor issues, 3.5-inch lift , 122k miles
2003 gold 4.0 automatic 3-speed Jeep Wrangler X - slight lift, -front end frame damage, small lift, 130k miles
1997 black 2. 4 automatic 3-speed Jeep Wrangler sport - on its last legs not amazing,200k miles, completely stock
I'm looking over the conditions of both the gold and green jeeps. I want to update the interior, but I wonder how cross-compatible the wiring is, I'll probably end up rewiring it all to put the dash of the gold 2003 into the 2000, I have to take a better look at the body and see what is the best to each to create the best truck.
I'm looking to create a Jeep TJ truck with a 6-foot bed and about 1.5 feet of cargo area behind the front seat.:
I'm in Colorado, if there a part you are curious about just send me a message
Pick a year and stick with it for wiring/PCM/drivetrain.
I favor 97s so the earlier the less complicated.
Agreed...
97-01 is CCD & then mid year 01.5-06 is PCI. You'll need to replace the whole dash wiring to use the 2003 dash in the 2000. You'd be better off to put the 2003 tub onto the 2000 frame...
Best of luck with this project. TJ based trucks are super cool IMO...
Reactions: macleanflood
Agreed...
that's so much work for the pay off. Why can't I change the dash and the wiring?
You can... Just can't tell you how much work it's going to take to do so other than stripping the tubs down to bare so you transfer all the wiring. So I'm not really sure which of the two options are less labor intensive. Pulling the tub off the frame IMO seems easier but I haven't done either.
You need to choose one complete engine, dash cluster and engine/dash wiring harness from one of your TJs to work with. From there, you choose the frame and body portions that best fits the selected engine and dash and their associated wiring harness.
Your 2003 is not a 3 speed auto, btw. And that one will mix and match the least with the other two jeeps.
Reactions: hear
good thread about a Jeep TJ truck conversion named Dumpster Dive:
https://www.jeepforum.com/threads/a-tj-truck-build-named-dumpster-dive.1300759/
this is what the cab should look like, two-part hard top:
with the addition of a little space in the back for the dog and 1 gearbox.
@jjvw
side note if anyone in Colorado wants to have a weekend party during the summer and make headway on this - I'm more then open to this.
Reactions: Weasellee
