I have a 2002 TJ 4.0 manual that is having issues turning over. I have already replaced the battery and starter multiple time and have had both tested since. I have also gone through the starter wiring issue form (
https://wranglertjforum.com/threads/jeep-wrangler-tj-wont-start-read-this.1201/). My issues starts when i place my ground from the battery to the block. If battery ground and wiring harness ground are connected but NOT attached to the block I don't get a voltage drop. As soon as I attach the ground to the block I get a voltage drop. I have taken a wire brush to the block and cleaned up the contact and it hasn't helped. Starter solenoid is either engaging or flickering, but not turning. I thought the engine might of some how seized so i tried bump starting it and it cranked and was close to starting but didn't start. Any ideas on where I would be getting a voltage drop on the block?
Here are a few things to consider:
Make sure that all ground connections are clean and tight, not just at the battery and engine block but also where the ground wires connect to the chassis. Sometimes a poor or corroded connection elsewhere can cause issues.
Use a multimeter to check the continuity of your ground connection from the battery to the block. There should be minimal resistance (close to 0 ohms). If you see significant resistance, that indicates a poor connection somewhere.
Sometimes, the area where the ground cable attaches to the engine block can be problematic, even after cleaning. You might want to try a different location on the block or use a star washer to help create a better contact or even add an additional grounding strap from the engine to the chassis.
Inspect the wiring around the starter, including the solenoid and any associated connectors for any signs of wear or shorts that could be affecting the voltage when attempting to start.
Since the solenoid is engaging or flickering, it may be beneficial to check the starter relay and associated fuses for any signs of being blown or malfunctioning.
If you’re still having issues, consider checking the neutral safety switch (on manual transmissions it could be a clutch safety switch). Sometimes, these can prevent the starter from engaging properly.
Perform a voltage drop test on the starter circuit to see if there's excessive drop occurring somewhere other than just the ground connection.
Given that you've already cleaned the block, don't hesitate to try some of the suggestions above, especially considering cleaning other ground points and verifying all connections. Good luck, and keep us posted on what you find!
