Hi, I recently purchased a 2005 4.0, 6 speed unlimited wrangler. The car has run perfectly until this past weekend when I did a tummy tuck. Since the TT, the car turns over a lot longer before starting, and then it idles rough and dies. It feels like the engine is not running on all cylinders. I pulled the code from the dash (on off on 3 times) and it gave me code P0522 which is the oil pressure sender.
A few questions for the group. I’m hoping someone could answer:
My plan tomorrow is to lower the skid plate and transmission to see if anything got smashed or any wires that were damaged, but I’m hoping someone has had experienced with this and has some ideas. Thank you in advance.
- from what I understand the oil pressure sender is used for the gauge in the dash and therefore it should have no effect on how the engine runs, is that correct?
- when I was doing the TT (i know stupid of me), I hadn’t unhooked the battery and I put a socket wrench on the battery terminals and it sparked for a second, is there a chance this affected the ECU and therefore the engine running properly?
- for anyone who has done a TT? Are there any wires, sensors or hoses that are in the way and potentially got smashed when pushing up the tranny?
