The PO installed a York compressor for on board air which is great. Moves stuff around and eliminated the belt tensioner.
Just an FYI, Danarch - I installed the ORO York kit on my 2005 LJ, and it had a spot on the new bracket to mount the tensioner:
Are you 100% sure there's no way to adjust belt tension, even manually? Belt lengths vary due to production tolerances, so it would be very odd not to have some way to adjust it with your setup.
Reactions: Danarch and Duner
I’ll have to take another look but didn’t see one. Seems odd to me too. My mounting bracket doesn’t look like that. They simple have a single bolt through the bracket to hold pulley.
Seems odd to me, but not seeing an option to adjust the tension.
Reactions: Duner
I believe the Kilby bracket has two bolts you turn to move the entire York to tension the belt, but I couldn't find a picture. I remembered that @Wildman had posted some pictures of how his JeepSpeed York bracket adjusted belt tension in, I think, a similar fashion. I "borrowed" the picture below from his build thread (I added the circle to show you where it adjusts):
Maybe that's how yours works?
Thanks for the info. Got me thinking and ran out to take a look. Likes like my bracket has a slotted base for the compressor to slide on. There are 4 bolts to loosen on the bottom. Can see in slots in the picture below. Then two bolts on the side with nuts to adjust the position of the compressor. Loosen the 4 bolts and turn the two nuts and compressor should slide. At this point though looks like it is all the way out. If an issue would need a slightly smaller belt.
Thanks again, got me looking I a a different direction.
Reactions: lBasket and sab
The Kilby bracket I had for the Magnum V-8 had a pulley that you adjusted.
Where the bracket for the 4 cyl from Kilby was slotted and you slid the compressor on it.
Reactions: sab
My original underhood mat was slowly deteriorating so I replaced it.
I used Under Hood Thermal Acoustic Liner from Design Engineering. (I'd asked for some, and received it, over Christmas.)
Basic steps: popped off the old hangers, removed the old mat, made a template for where I wanted coverage, traced template to liner, cut, test fit, installed.
Before:
During:
After:
Reactions: John Cooper
Before:
During:
After:
Looks good. What size did you get to cover everything? I need to do that to mine soon.
I still ride past mine a few times a week. Pretty much just like I sold it back in 2011 except it hasn't moved in the past 10 years, and the guy who has it won't respond to my request to buy it back.
I've only sold one of my Jeeps locally, so I wouldn't have to see them again and regret it. The one I sold locally looks like it hasn't been washed since I sold it (8 years ago). The guy loves it and drives it daily though. 🥳
All of mine were sold locally, except the CJ8 that I totaled.
Most were to young kids who destroyed them. :cry: :cry:
That's what stinks, I bought them, fixed them up and they looked and drove great.
Then got trashed.
Oh well I made money off of all of them but one, and broke even on it.
Washed it last weekend right before the virus hit me and sucked away all my energy for the rest of the week. Somewhere in there I remembered to soften the shocks and oh boy what a smooth ride. I always forget once I get back from a camping trip and unload it. Ordered a Mopar resistor motor for it. If I can get all my responsibilities taken care of by Wednesday, I may be able to sneak out for an overnight trip Friday or Saturday.
