Cruise control buttons
MountaineerTom
LJ Enthusiast, Retired USAF Weapons Loader
Sumter, SC
Can the cruise control buttons be removed and cleaned relatively easy? Mine work, but sometimes you seem to have to press a very specific spot to set it. Was thinking maybe the contacts need cleaning or something. Not near my Jeep to check it out though.
Mine are doing it also,I have a spare set,I’ll check it out.
Reactions: MountaineerTom
Yes they come apart relatively easily
Pry next to the pivot using a small flat blade screw driver, should pop off with relative ease.
Remove the rubber protector thing
Clean as desired with isopropyl alcohol.
Perfect, thank you.
Are they just snapped into the steering wheel housing or is there a screw in the back. Disregard, I understand the part about prying at the pivot to pop it out now.
Again, not near my Jeep to look at it.
Reactions: Tronner
Perfect, thank you.
To remove them from the wheel, you would need to remove the 2 9mm bolts that hold the airbag on and then remove the Phillips head screw that holds the button to the frame.
Easier to clean them while on the wheel.
I see, thank you. 👍🏼
Did you mean they are easier to clean when out of the wheel?
Here is my deal. My cruise works at times. Sometimes the light will not come on. Sometimes when it does come on, it goes back out. The vacuum line is good. There are no other issues that the clock spring would affect. Once the light is on, everything works as it should. Brake switch kills the cruise like it should and the light stays on.
I heve found pressing on different areas of the cruise switch seems to change the cruise light coming on.
To edit: No codes show up.
They are easier to clean while still on the steering wheel, However for your issue I would recommend removing the airbag and checking the connectors that attach from the clock spring to the switches. It is a simple task, just be sure to disconnect the Battery and wait a few minutes for any capacitors to discharge. From there I would check the Vacuum cable actuator that sits in the engine bay.
For those with earlier model TJs, it looks like the cruise control (CC) buttons are a different design. I was also having the same issue where it seemed like I had to push really hard and leave it pressed for a few seconds or in a very specific spot. For reference, I have a '98.
Removal of the CC button housing from the steering wheel is very easy, a T20 torx screw can be accessed from the backside of the steering wheel. To make removal easier, you can remove the airbag secured by 2 hex screws (forgive me I'm forgetting the size but I think it was slightly larger than 3/8", like 7/16" or 13/32"). PLEASE DISCONNECT THE BATTERY IF YOU INTEND TO DO THIS. Once the torx screw is removed, don't try to pull the housing off axially (torwards you) as you'll break the tab securing the CC button housing to the steering wheel. Instead, you'll have to remove it by sliding the housing radially (torwards the center of the steering wheel). I think you can do this without touching the airbag but since it's two screws I usually opt for getting the airbag out of the way.
To take the pivoting button off, it's easier to get to the pivot point from the rear (those white tabs in the photo above). I just take a screwdriver to easier accessible one and then you can pop off the button. Be careful because there's also a rubber protector/boot and some small metal bridging plates that may fall out since the button is upside down.
Flip the CC button housing right side up and remove the rubber protector/boot. That will reveal the bridging plates which can also be popped out to reveal the contacts. The contact pads looked clean so for the older design switch, I think the issue is more about general wear and it being difficult to fully depress the bridging plate.
What I did was since there are three contact pads/bridging plates but only two button functions for the left steering wheel CC button, on/off & set, I took the bridging plate from the middle function that isn't used and added it to the backside of the rubber protector for the on/off function. Since all you're doing when pressing the CC button is pushing against the bridging plate, why not add a little extra material inbetween the button and the bridging plate to make it easier to deform. That's what I did for the on/off function and now that it's reassembled, all I have to do is a nice, easy press of the button and CC turns on without any fiddling.
As a departing tip for where to press on the button itself, the little nubs on the backside of the pivoting button (not photographed) that deform the bridging plates when pressed are right behind the "O" in "Off" and the "S" in "Set". If you're having trouble engaging either function, focus your pressure in those areas of the button.
@Tronner , thanks for the tips on this. I finally got around to doing it. Really easy to do. I took a small brush and some light compressed air and blew all the dust out of there before cleaning with alcohol. Button works on every press now.
I didn’t take pics of the switch on the right side of the wheel, but all three contacts were tarnished looking. Alcohol didn’t take it off, so I used a small piece of 1000 grit sandpaper and cleaned them up, blew the dust out, cleaned with alcohol and reassembled.
Reactions: Tronner
View attachment 602728View attachment 602729View attachment 602730
Nicely done... I will be doing this soon.
Glad to hear it worked out! Thanks!
