Received my links a few minutes ago. Is the wrenching flat part of the redesign?
Wasn't there a very specific reason they stopped doing that back in the day?
The reason the flats are not needed and should not be there is to prevent people from adjusting the arms into a bind with a wrench.
When required to adjust the length by hand, you can easily feel the bind as it develops and correct it. The result is a better setup that isn't fighting itself.
Right... Isn't that why they stopped putting the flats on in the first place, because using a wrench on them was causing binding or stripping threads?
The reason is to prevent binding and, to the extreme extreme, stripping. Mine from the very first production run did not have flats. Nor have the two other later kits I have seen in person. I have a vague memory of the short arms having flats for a brief moment. The reasons against wrench flats applies there, as well.
Ok yeah. I thought I had read they once came with flats then stopped machining them for flats because there was no good reason to need them. But maybe not.
Waited 3 years to finally pull trigger on everything.......guess I will wait longer
Fyi: That hand written note from Gerald is photocopied...... How many are you shipping like this that it makes sense to photocopy that note?!
They're the savvy designZ arms![]()
How much crack did they smoke to come up with those prices?
