Front diff hose dragging on the ground
Tooonz
Central Mass
I’ve been driving my TJ to work to work out the bugs, the past two days I took it on some longer runs on the highway.
Today I took if for a two hour errand run, when I returned I wanted to go through the car wash to wash the salt off.
Before I pulled the attendant motioned under the jeep. I got out and the diff hose was dragging on the ground.
I read it attaches up on the drivers side of the radiator but I see no clip, and the vent is broken off the end of the hose now.
Does anyone know where I can source the clip and vent?
Here the link to the ➡ Clips
And heres the ➡ Vent
Or you could just use a ziptie which is what i did, It doesn't bother me enough to change over a to a clip even though i have em
Also it doesn't necessarily need to be on the radiator unless you go deep in water.....but yeah i digress,The links are in the underlined words 😄
Reactions: MikekiM and lBasket
Or you could just use a ziptie which is what i did, It doesn't bother me to change over a to a clip even though i have em
Mines ziptied too. Not exactly a lot of force on it lol
Reactions: D's Jeep Wrld
Usually bolted on.
