You probably will get those points and need them
I've never understood it either. Most that have them in the wheel wells are probably there for the "look" only. There is almost no light that reaches the ground. Same for the ones that are RGB rock lights. What good is a pink light?
I had enough wire (10' per light) on the passenger side and front to get them all to where the AuxBeam controller is (behind the passenger headlight). The driver side and rear I connected the 2 rear lights behind the driver taillight. Then ran them all up to inside the driver fender, connected them all together, and ran 2 wires in a jacket across the firewall to the AuxBeam. <— That was a lot of explanation to just say that I connected them to the AuxBeam![]()
With as bright as these are I can see using just six.
One on the front frame cross member, one under the back bumper and one on each side, under the doors.
Do you think you could have daisy chained them down each side by cutting the wires just before the LED, soldering the next LED in-line and then doing the same with the third/ rear LED? So, have three (or four) all soldered together in series resulting in just one pair of wires for each side? Connect those two pairs and send just one pair to the Auxbeam? It's just two wires per light?
