My 90 degree air locker hose fitting on the front differential is loose and leaking. What is the best way to replace the fitting with a new one?
It seems like it is a press fit into the housing but what does the barb fit into inside the housing?
Can the fitting be pulled/pried out and a new fitting pushed/tapped back in? Or is it more complicated than that?
I'd like to fix the leak but I don't want to cause a bigger issue for my daily driver in the process.
Thanks in advance for any advise you can give.
