Battery replacement questions (is AGM always the way to go?)
I know 2 things to be true. AGM are the only thing I will run due to the non spillable nature which keeps acid away from stuff I tend to like. AGM are not the tiniest bit forgiving when it comes to being left to sit in a discharged state. If you miss that it ran down and sat for even 24 hours, you're likely going to need a new one. If you are one who needs to let a battery sit for a few weeks at a time, get a good maintainer on it.
In your experience how long is too long to have an AGM sit without a maintainer on it?
Does your Fridge have a low voltage cutoff? My Dometic has it built in.
Yes it does,it did shut the fridge off,but we left town for almost a month (fridge not on)and I forget to plug it in . And keep Wes dead when we got home.i thought there might be another type of low voltage shutoff for when we forget to plug in the shumaker.
Reactions: Apparition
Mine is hooked to a maintainer whenever it isn't being driven.
Edit: Using this and the second pic is where I plug it in.
My jeep sits a month at a time frequently with no issues. It's also handles a high watt, big kicker bass, multi amp sound system like a champ !
Just to clarify… when I say I’m looking for a maintainer that will operate in cold weather I’m talking at least -25°C/-13°F.
I’d prefer to have something that could handle a little colder than that yet.
I'm sure there are a lot of good maintainers out there but IMO one of the best is a Victron Blue Smart. They make both the IP65 and the IP67, IP67 is onboard mounted and IP65 is portable. They make them in ranges from as low as 5 amps up to I believe 20 amps. Fully user configurable and Bluetooth to look at history, trends and to customize charge profiles to fit any battery type. 5 modes, bulk/absorption/float/storage and recondition. In storage it will stop charging when the battery is fully charged then as voltage drops it will kick back in as needed.
I'm using 2 IP65s that I plug into extensions at the front bumper. On the Jeep I got the NOCO for it's small footprint, plus the Jeep sits outside so I wanted something permanently mounted.
Reactions: g.hayduke
Mine's sits (in a garage) for 2-3 weeks several times a year, and occasionally longer with no battery tender.
Always starts, even in the winter.
IMO, if it doesn't start, even after several weeks undriven, you have other issues.
YRMV
I posted about my troubles with Northstar about a year ago:
Lots of great responses guys, thanks! Thinking I’m going to go AGM and if it sits for more than 2 weeks (or do you guys think that’s too long?) without being driven then I’ll throw a maintainer on it until it is driven.
Okay I was looking at the NOCO but not functioning in cold weather was a concern I had as, like I said, my TJ sits outside year round.
Anyone know of a maintainer that won’t have a problem in the cold?
CTEK is a good option, they have a cold weather charging option. They also have a dedicated cold weather charger for extreme cold temps, like areas that see -50 on a routine basis.
Currently have my CTEK charger for the tractor, and both Jeeps use a dedicated on board Victron charger. They have portable ones also. I like victron components, great quality, and they have a bluetooth app that connects to your phone so you can see charge cycles, voltage, etc.. They have a whole slue of stuff I use for the "house' system to monitor usage, remaining battery life in percent format, total ah used over a specified period of time, etc... but that's way excessive for just a maintainer.
Reactions: B1Toad
Yup came across the CTEK MUS 4.3 Polar. Rated down to -30°C, little spendier than what I’d like but might be the best bet for what I’m looking for.
O - M - G
-13F ??? I say MOVE ............... !!!
Reactions: James9100
