I've only found one cooler that works as well as my somewhat picky needs dictate. 99.9% of Jeep owners won't run it because it costs almost 400 dollars for a passive cooler. It is the most cooler you can mount in the grill area easily but even then, you will have to pull the V bar to make it a clean installation. It's in a build thread with the Orange TJ Unlimited. I have not found a fan driven under the tub that is worth the money yet.You mean cooler?
I use a Flexalite 4116TJ in front of the radiator. It is a popular choice.
Jerry Bransford likes his Derale 20561 with fan mounted underneath his rig. Chris, our Administrator, just purchased one.
There is a B&M cooler favored by some TJ owners.
___________
Edit: I see that you edited your post to read "radiator" rather than "auto".
The answer to that question is OEM Mopar. With the possible exception of adding an auxiliary transmission cooler, keep your cooling system stock.
