Hey Andy,
Thank you in advance in helping
So far I've gone through tires, wheels balancing and rotation. I've replaced ball joints, tie rods, hubs, axle ujoints and control bar. Even pulled the stock cam bolts and put in deletes so I'm sure I'm not 100 percent on caster here.
Before I did all that replacement of ball joints etc.. the first thing I pulled was the front DS. It didn't make the shimmy go away but made it defined more.
I believe this has to do with something front axle or driveshaft or something because when I did use the factory caster bolts and adjusted the caster from 6 to 7 or 5.5 even, the speed the shimmy would start and stop would change. 6 caster was at 57-62 and 7 caster was at 55-60. Now without the cam bolts in there it's at 62-66 so I'm sure my caster is at 5 or 4. I need to adjust caster.
So whatever is doing it, must be upfront somewhere. Removing rear DS makes it all go away. So I think what's happening is without the rear DS in, things get mushed forward a little and it deletes the shimmy. Why we are thinking upper control arm bushings.
