I am not getting power to my high and low freon cutoff switches. I am getting power to the fuses and relay. I have swapped out the relay with a known good one. I opened up the dashboard to check the controller for . melted wires and found none. My fan switch works in all four positions.
With the key forward and the AC fan and control in the off position I have power on the large green wire in the middle of the connection on the right. Once I turn the blend switch to any position I loose power on that large green wire.
How can I jump the wiring to manually run my air conditioning?
How do I check if I am getting power into or out of my PCM?
Does anyone have a direction to look in the control panel.
