Greased everything that has a zerk after the deep water . I still need to grease the hard to get to double cardan grease fitting on the front driveshaft .
Redid the lift kit by reinstalling the OME rear springs and added a 1 inch spacer up front . After the last trip I decided I want the extra inch of lift .
Installed Black Max shocks and steering stabilizer .
Inspected the front vent tube , looks good . I'm guessing the water came in through the axle tubes .
That would imply that you have an axle seal that's bad.
The seals were installed in February when the regearing was done . This was the first time it's been trail riding since the regearing.... I know , that's sad 😢. It's also my understanding that if you overfill the Dana 30 it will leak oil out the tubes .
Reactions: reddvltj
Yep and breathers don't always stop that from happening... The cap on the breather can restrict backwards flow. Its main function is keeping the diff from becoming pressurized. It's by far not a perfect design and sometimes shit happens.
The main function is for pressure neutrality.
Agree to dissagree, the cap on top of the breather is pushed away from the plastic tube adapter when it's under pressure. When subjected to negative pressure it can be sucked down to the plastic and (while not completely sealing it off) temporarily cause a vacuum in the diff.
Reactions: John Cooper
IMG_7382.jpegIMG_7379.jpegIMG_7380.jpegWell, prepped and painted diff cover and skid plate. Got all old gasket sealant cleaned off, bolts as well. Wire brushed gear housing around the cover area coated with Eastwood matte black rust encapsulate. Cover VTH red engine paint, skid plate black, from paint lying around. Better than nothing. Let all cure a bit over night.✌️
put the old wobbly jalopy in heated storage last week, for the winter.
Sadly, at 70 YOA, I'm getting to feeble to get in or out of a Jeep
Where did you put your Jeep? ;)
I think @TheBoogieman meant the actual address. Knowing it will be left all alone for months gives him plenty of time to come by with a trailer and take that jeep off your hand's. 🤣
I was thinking he put himself in storage after his comments. ;) I know @John Cooper got it.
