No 4 low
fingerscrossed02'
Thornton,co.
I just put in a new front drive shaft , it fixed vibration and noises... I have trouble with changing gears especially 2nd and reverse. I have no 4 low. I just get a zzzzz kinda noise when a let the clutch out. Doesn't do that in hi or 2 but so don't know if it's the clutch or t case maybe?
Reactions: inkedrose
Have you adjusted the t-case shift linkage?
Reactions: Rickyd and AndyG
Odds are its the linkage - not fully throwing the actuator.
Be good to really check it out for bind and bushing failure ....and it is adjustable as the above post indicates.
