When looking for a HP30, which vehicles are a straight swap to a TJ, or do the axle brackets always require modification when swapping in a HP30?
A 93-99 XJ is a direct swap.
slightly different take here, I'd first be sure you're substantially invested in wheeling before spending the money on selectable lockers because they're expensive, whatever source actuates them. Maybe slap a lunchbox locker up front & wheel it a few times to see where that gets you, cheap as hell and you can probably slap it in yourself.
Just saying, I went wheeling once shortly after getting my TJ in 2016 and immediately put in 30 spline Super35/Super30 with air lockers plus a bunch of other nonsense, wheeled it pretty religiously for 3 years then all the air came out of the balloon (figuratively) & lost I all interest, spent the past 5 years un-building it, aesthetically anyway as all the performance shit is still underneath, and using it as a convertible street queen. In hindsight I could've saved thousands by leaving it largely intact but adding a lunchbox up front & maybe a Detroit in the rear with stronger shafts.
If you're sure you want/need the big daddy lockers, I'm pretty sure they'll all serve your purposes very effectively.
Selectables are amazing, in part, because they don’t exist unless you want them to.
I wouldn’t want a Detroit or any lunchbox locker in a vehicle that wasn’t dedicated for Offroad use. Even then, I’d rather pay for selectables so I’m not always locked in 4WD.
As it stands today I'm driving on the street only on axles that are way overbuilt for those purposes.
I understand. I know you are bummed about the money, but are you sure you'd be happy driving around on pavement with a Detroit in the rear...or a lunchbox in the front while in 4WD in snowy conditions? I'd gladly pay extra to not deal with that.
I believe your general advice to OP is to "know why you are building it before you make your choices." That's something I think all of us can get behind.
I have yet (besides what I read) been able to have any issues driving in the snow with a lunchbox or Detroit in the front axle. My YJ I drove many winter in 4wdH with a front Detroit and either lunchbox or limited slip in the rear....or a lunchbox in the front while in 4WD in snowy conditions? I'd gladly pay extra to not deal with that.
So far that adds up to 4 cents
Do you find that if you slip sideways the lockers let you give it gas to straighen out where open doesn't?
In theory that seems correct but it real life I honestly don’t think there’s a noticeable difference in real snow or ice. When there is low traction you either slow down to gain traction or speed up and slide there. But i think snow is east to drive in. It’s traffic that’s dangerous![]()
All I want to know is what you would have spent the thousands on?
An automatic locker in the rear is not the devilI have several hundred thousand street miles running rear Detroits in many things and wouldnt have it any other way. And selectable in the front to not kill turning radius.
I question anyone that would choose run an auto locker in the front of anything. That is truly terrible.
