I always liked how the Savvy had rigid mounts at the frame and the isolation at the transmission. Getting that to work out cleanly without robbing clearance is no small feat.
This one is a bit more tedious than normal. There is not enough front to back space between the front of the Atlas and the back of the Rubicrawler to bolt up the trans mount adapter and then the OEM transmission mount because the holes overlap. The adapter bolts up into the bottom of the RC like stock, but the transmission mount goes over studs and then nuts hold it up to the adapter. Had to get creative with countersinking some flat heads and welding them in to turn them into studs sticking down.
Oh, sure - put me on the spot. I'm not a trained seal that performs on demand - especially before coffee!
I think we need to start a petition to get Blaine to consider changing the name from BMB to WMB (W for white) because "black magic" has connotation of using superpowers for evil and selfish uses .. and what Blaine does is the opposite. He uses his powers to make something exemplary not for himself, but for others. Case in point (and grab a chair and your favorite drink), the transmission mount and the cross member he's built for my orange jeep.
I am not even exaggerating here when I say that looking at the final finished items you just have a "How the F was that done?" question. Without him showing some intermediate photos, me going, "You got 'splainin' to do" and him humoring my curiosity, I most certainly would be left scratching my head. Or worse, not even notice or appreciate just how much thought and energy that went into the work. Stuff like this what makes me really smile because more than just the technical parts, and despite the lack of explicit and intentional beautification/ornamentation, there is a certain "form follows function" charm to Blaine's work (in contrast to "form follows precedent") here that is just really nice to see.
I will start with the transmission mount. Given the nature of most normal auto shops, and how little they understand (or care) even the seemingly normal stuff, Blaine wanted to design a mount to bolt up to the Rubicrawler and accept a stock transmission mount with zero changes to the stock mount, The idea is that any shop doing maintenance can readily change the mount in the future when required. However, this was not trivial to accomplish. Blaine explained the challenge very clearly in this post -
The clever solution he came up with is a 2-part mount, comprising of a base (that attaches to the rubicrawler), and then another mount bolting to the base (which accepts the OEM trans mount). Below is how all of it goes together ...
First is the transmission mount adapter base that attaches to the rubicrawler.. the sides are 1/4” x 2” to stop any chance of failure. It bolts up to the trans mount location on the Rubicrawler, like in the photo below. Notice there are 4 holes, 2 for OEM bolts and 2 for countersunk flatheads. First, the 2 regular bolts install to locate and hold it up but not tightened down.
Then the flatheads are put in, and fully tightened ..
Then OEM bolts are removed.
Ahead of time, Blaine had already custom designed an adapter that attaches to the base in the above photos. The adapter has studs with countersinks on the top side and flat head screws stuck in flush, and then tig welded around the edge on top so the screws cannot spin. The OEM transmission mount will mate to this adapter, and once the nuts on the studs are tightened, they will pull studs down into the countersink (so the welds only have to prevent spinning until the nuts are tight).
Below photo shows how the adapter attaches to the base. The connection between the base plate and adapter plate is made very strong, with 4 bolts through the sides (pink arrows) and the two OEM bolts that were removed earlier after installing the base.
Notice the fitment of everything .. and there is a very nice element of long range thinking here that will become clear shortly if you cannot spot it yet. I certainly did not till Blaine told me .. I will wait for @sab or @Mike_H to perhaps spot and comment before revealing it
With all that White Magic™ done ... the transmission mount bolts up to the adapter just like OEM.
Now ... ask yourself this question - How was this design process done? From adapter mount down, or from transmission mount up?![]()
It is here. When we clamped the outer rails up to the inner that was built first, we put a 20 thou shim in the form of a strip of material between the inner rails and the outer to create a small gap between them before we welded. I'm going to send this stuff out for powder coat and that adds a pretty good film thickness when you get it on both sides that will butt against each other. To save myself from having to sand off the PC on at least one face or having to beat them into submission, I built in a powder coat gap. I do the same when I have powder coated corners landing on top of powder coated backers for rock rails.Sorry to disappoint...I'm just not that smart.
Oh, sure - put me on the spot. I'm not a trained seal that performs on demand - especially before coffee!I'm not seeing Mr. Blaine's strateegery... Mike_H, all the pressure's on you now, my friend.
That's an ingenious way of solving the problem of overlapping mounting holes.![]()
Sorry to disappoint...I'm just not that smart. I can only hazard a guess about maybe marking those brackets so someone coming along later would have some clue that the two flange head nuts have to be removed to expose the flatheads...I can see some wrench jockey not knowing how its put together and getting a HUGE prybar out and popping the threaded bosses off the rubicrawler.
Regarding your last question about top down or bottom up, I'd say it was designed from the trans mount up.
I can always send you more coffee![]()
Oddly coincidental to what I'm doing right now. In fact, I was in Machinery's Handbook a short time ago getting tolerances for hex bolts in order to have some laser nut washers made. Since I don't like to do research every time I do something, I made a spreadsheet for future reference (notice the fifth column):
psrivats, I think you're giving Mike_H and I too much credit - it would take some clairvoyance to see what Mr. Blaine did there! Great thinking ahead!
I didn't have any .010 shim stock.![]()
I only have 2 feeler gauges and the only reason I have 2 is so I can check to see if a rotor is centered in a caliper saddle. I protect them dearly since they give me info I can not get with any other method. I won't be welding near them.I have a box of feeler gauges that have been scavenged over the years for shim stock. Cheapest way to keep a supply on hand.![]()
Both of you still run circles around me!
That huge pry bar scenario isn't too far fetched from the reality of what happens in shopssource: YouTube
So you think I build stuff crooked?And, yeah...No way would I have gotten there about the paint gap thing. No way in heck.
On your phone maybe.No! That gap doesn’t show up well in pictures
